Triple wax foamer problem
Mdbordelon318
I have a triple wax foamed set up. Foamer gun and 3 tanks. When it's on it comes out more liquid than foam . I tried adjusting air and product with no luck. Most times it is very runny and spits air intermittent. Any ideas? I'm a newbie to carwash
Rfreeman
Ft. Worth
Could be your dilution ratio maybe you need more product in your tank.
If you have foamers make sure their clean or that the material inside them is still there. Had a similar issue and when I opened up the foamer it was empty.
Also make sure your getting could product flow after the solenoid. Don't where yours are but mine are inside the equipment room so a quick disconnect and bucket to catch the liquid to test.
I'll bet you'll find the foamer material at the elbow on the end of the boom.
