washregal
I am baffled - I have an older triple foam system with three solonoids at the bottom of the system.
My problem is - when the system is in use or there is demand it apears to work fine.. When the dial is turned off clear coat or shut off .. my flo jet pump goes crazy.. The pump hammers or ait binds...
I have changed the check valves, and air regulators.. aside from changing all the solonoids is tehre anything that anyone would recommend?
I looked up at my Red clear coat color from the hydrominder it apears to be bubbling.. could this be the problem?
