Triple foam rinse?
wash12
Wondering what everyone else is doing after there triple foam, on one of my packages I eliminated the low pressure rinse after triple foam to a HP rinse with drying agent followed spot free and 2 drys.
My question is it necessary to rinse the triple foam off before hitting it with a final hp rinse with drying agent followed by a spot free rinse and 2 dryer passes. Trying to cut time off the wash I did notice a bit of triple foam on one car still left in the side mirrors but very minimal.
Whats everyone else doing?
Depends on your machine and chemical. If you have a machine with a quick, productivity rinse like the laser you could use that for a quick one pass rinse on a fast speed. Also get a foam that breaks fast and that will rinse with your next cycle.
A lot depends on what you are using for your triple foam. If you could use a product like a foaming clear coat protectant you would have no problem. If not if you hit it with the drying agent first then rinses it might do the trick.
