Tri foam VS Air Dryers
Yeti55
Hello everyone ,
Looking to invest in another function at my self serve wash in Canada , recently added one air dryer and seems to be doing ok.
if you had the option to install a tri foam or dryers which route would you go ?
Triple foam seems to be non existent in my province , can you run it in the winter ? Is the air logic from kleen rite the most cost effective option ?
I would add both, triple foam first then air dryer, if budget requires spreading them out. They make winter tri-foam chemicals, don't know if they'll work for Canada cold temperatures. There is also an automatic air/washer fluid blow down system that seems to work well for some of the northern climate members on this forum.
