Technical Help for a ShurVend Wall Unit
ScottV
Upstate NY
Corning, NY
I have a 12yr old ShurVend “Mini” wall unit that I bought from Jim Holve. The MEI7000 coin acceptor is starting to give me problems with messages like ”Disabled By System.” There were no manuals that came with the machine, that allowed for troubleshooting. Does anyone know where I can call to get help with this issue? It’s not the MEI7000 because I have a new one on the shelf, swapped it out and the same message appeared on the display.
Eric H
Leominster, MA
Does this machine also have a bill acceptor? Is that being disabled too?
ScottV
Upstate NY
Corning, NY
Thanks Eric. With some more testing I found that the coin acceptor will accept quarters up to $2.00 and then it starts rejecting them. A combo of $1 and quarters works up to $2.00 and it will take nothing more. If you select a $2 item, it will dispense. If you select a $1 item, it won’t dispense. The error message on the coin acceptor says “Check Vendor, Disabled by Machine.”
Lexington, Ky.
I've had that issue pop up randomly for years. Haven't found the exact cause or a real fix, but turning the machine off for a min then back on usually resolves the issue.
