Tankless Heater, Calcium, and easywater.com
blurdgman
Please offer any info if you've installed a tankless heater system in the past year or so. Have you had any problem with calcium buildup? Have you any experience with <http://easywater.com> saltless soft water maker?
bigleo48
I have six tankless water heaters for the past 3.5 years. Only soft water goes through them and I have not had any buildup as there is nothing to build up.
BigLeo
I have had some tankless heaters going on 15 years with no problems. Only soft water through them and they should be fine.
I know of someone who used a product similar to the "Easy Water" device - he ended up replacing his boiler because the tubes became completely plugged with calcium, and the lack of flow caused some of the tubes to buckle and burst.
