Switch over time from soap, rinse, wax
mrod247
New to the forum but owner/operator for 5 years in Nor Cal. I have a 3 bay wash. One bay has recently been delaying(taking about 30-40 seconds) in switching over between rinse, soap and wax. The control dial seems to be working fine because when I switch to foam brush, it switches immediately. I replaced the valve for the soap because it was leaking/not closing all the way. That did not fix the delay though. Anyone have advice on where to look? Seems improbable that all three valves need to be replaced. Thank you for any advice/help that you can provide....Marcus
Do you know if the hose has absorbed any soap? As generally older houses after a long period of time they can actually absorb soap which can affect the change over times
If you have a spare hose try and see if you can put it in place of that high-pressure hose that runs in between your pump stand and the bay
Try cutting back on the inlet water to make the pump pull a little harder.
