On the super saver, when i select wax or soap, squeeze trigger cause to drop pump pressure and lots of vibration. On rinse, its normal no vibration or lose pressure. Any suggestions? Btw this is isolated only on one bay.
Water for soap and wax are drawn from the hot water tank. Rinse water is provided from a pressurized line. You've likely got a problem with the check valve or ball valve on that bay under the water tank
It was both. The ball valve handle turns but does not shutoff water which threw me off. After several time shutting valve off, the handle finally broke but the valve did not closed. Water everywhere... Had to empty holding tank and proceed to replace both check and ball valves. that was fun... Thanks Greg!
Why they didnt build these units with a live swivel connection under that tank is something I just dont understand??? Obviously some engineer that has NEVER worked on one of these in service is quite obvious. I am thinking about just sawzall all of them off and redo them with a serviceable swivel on each bay. Thoughts??
I thought about doing the same, but figured I would wait until one failed and then do it when the tank was empty. To be fair, at one wash it's been 13 years and nothing under there has failed yet.
