Because there is an New Express Wash right across the roadif you really want to differntiate yourself in a market already full of touchless machines why not look at a friction rollover? i've heard the operating costs are very low compared to touchless. just a thought...
If you have sticker shock with the WW quotes, wait till you get a Petit quote. I own both and I like my Razor better. Here are a couple of examples. The Razor is far more economical when it comes to chemistry and water. Razor having smaller nozzles creates more of an aerosol effect that foams your presoaks nicely with a better show. The Petit with the larger nozzles has more of a wet foam look. I have short bays and the Petit with two pump stands really isn’t that much faster than my Razor. We bought a Petit to replace an older 8 ft IBA. They clean about the same.Thank you for all the suggestions. We will be getting some more quotes in the next couple weeks. I’ll keep you informed the double barrel does sound like a good option. We will definitely get a price on that too also going to check the Petit we have the water wizard halfway fixed so we should be OK with that for a while
For Razor Hyper Force (without plumbing and electrical) we were quoted $200k without installation (it included everything we wanted) for Petit we got quoted $265k (again no installation, with stand alone dryers)If you have sticker shock with the WW quotes, wait till you get a Petit quote. I own both and I like my Razor better. Here are a couple of examples. The Razor is far more economical when it comes to chemistry and water. Razor having smaller nozzles creates more of an aerosol effect that foams your presoaks nicely with a better show. The Petit with the larger nozzles has more of a wet foam look. I have short bays and the Petit with two pump stands really isn’t that much faster than my Razor. We bought a Petit to replace an older 8 ft IBA. They clean about the same.
Just wondering if they gave you any idea on what it was going to cost to install?For Razor Hyper Force (without plumbing and electrical) we were quoted $200k without installation (it included everything we wanted) for Petit we got quoted $265k (again no installation, with stand alone dryers)
100% this.Then you should get a Petit.
This guy has to be a botI’m afraid you are off by $30000 on the install going with a different
100% this.Or a Typhoon
No sir, I've known Tim for several years.This guy has to be a bot
I was talking about the EWash guy. I should have said “that guy”No sir, I've known Tim for several years.
