Might work well if you plan to bathe in a bay with your wife...Candlelight with scent. They have a awesome selection and deals at bed bath and beyond on scented candles.
This is still too much of an emotional decision on this board. Did the payback. LEDs are way to go with a 3 year payback for me from a replacement perspective, putting in new there is no doubt, 40%ish or less of electric for the same lumen output depending on which manufacturer you go with. Do the math.
Something you're probably not figuring in is light output. LEDs are not more efficient than fluorescent or HID. They're just lower wattage. I want the bays well-lit, and replacing 320 watt metal halide with 100 watt LEDs won't make that happen. Yes, if the metal halides are old and weak it's probably going to look better with new LEDs, but it will never be as bright as new HIDs.This is still too much of an emotional decision on this board. Did the payback. LEDs are way to go with a 3 year payback for me from a replacement perspective, putting in new there is no doubt, 40%ish or less of electric for the same lumen output depending on which manufacturer you go with. Do the math.
I was typing that as you were posting your data - it seems we've both done the same math. FWIW, I've been replacing the Scottsdales with 4-bulb T8 fixtures (116 watts each based on .97A at 120V) and at a third the cost per fixture and 36,000 hour bulb life I'm way ahead of LEDs.
Four Phillips Alto bulbs is $7.20; Phillips ballast is $24.What's the cost of a replacement bulb and ballast in those?
Going by the ratings of the parts (36,000 hours for bulbs, 100,000 for the ballasts) I'm still way ahead of LEDs. At the 100,000 hour mark of your LEDs when you may be spending another $600 per fixture to replace, I'll have spent $45 in bulbs/ballasts.MEP - I agree for a "replacement" T8s are very attractive and the cost is right but eventually they will go the way of MH and you still deal with ongoing maintenance costs which no one ever figures in. The LEDs I went with have a 5 year warranty and a 60k to 100k life expectancy. If you factor that in to the overall cost model "NEW INSTALLATION" like we are speaking here, it is pretty much a no brainer. Also if you look at my numbers you will see Lumens is part of the equation, which is light output.
I'm assuming it's because all the light from the LEDs is projected straight down at the ground, where the Scottsdales throw the light in a roughly 270° sphere. I'm seeing the same thing from the fluorescents, that most of the light is cast down.MEP, if you look at specs you are 100% correct. But I have to say with 150W LED fixtures from TSS virtualy side by side with 320 W Scottdsdales (Replaced some old 400W MH) I have to say the LED's are whiter and brighter.
Specs say I'm wrong. I know. It's kind of like "What are you going to believe, what I say or what your own eyes see?"
I have also seen the same with redone gas station canopies. Can't explain it but there it is.
