T Twodose Active member Joined Sep 10, 2007 Messages 658 Reaction score 86 Points 28 Location NE Pennsylvania May 30, 2022 #1 When purchasing from a metal supply co, what size is the 1/4" pipe that would be used to make a wand? Is is 1/4" ID schedule 40?
E Earl Weiss Well-known member Joined Aug 31, 2007 Messages 6,211 Reaction score 792 Points 113 May 31, 2022 #2 Why would you do that as opposed to buying a wand? You won't be able to have the pipe tapped at one end of 1/8" nozzle so you will have to add a coupling for a 1/4" nozzle.
T Twodose Active member Joined Sep 10, 2007 Messages 658 Reaction score 86 Points 28 Location NE Pennsylvania May 31, 2022 #3 Using it for something else, I can tap it myself.
MEP001 Well-known member Joined Aug 30, 2007 Messages 16,667 Reaction score 3,937 Points 113 Location Texas May 31, 2022 #4 Don't know what the schedule size is, but it should be a bit over 1/2" OD.
C Carwashking Active member Joined May 7, 2017 Messages 105 Reaction score 43 Points 28 Location Dallas May 31, 2022 #5 schedule 80 is what I used for high pressure.
