Stainless Steel Mixing Tanks / Alternative
edredtop
The previous owner at one of our washes had mixing tanks all over in the equipment room with water and product lines running everywhere.
I decided to upgrade the low pressure stuff to Air-Logic and consolidate the mixed products all in one central area and found I needed/wanted 4 of the square stainless steel tanks... (I'm getting towards the tail-end of this job now)
When I found out it would be $419.89 for the single tank and $652.05 for the triple tank for a total of $1,071.94 I decided to look for alternatives.
After searching around, I found a restaurant steam-pan on Amazon for $34.28 each making the project's cost only $134 plus the cost of some stainless fasteners and they work great.
Hope this helps somebody...
Are you supporting those underneath in any way?
No support.
Used a peice of 5/8" plywood wrapped with an old aluminum car wash sign. The aluminum is to avoid wood rot failure in the future. Sprayed clear coat on it for water resistance. Mounted that then mounted the pans. The pans have a nice lip that sit on the mount and then put stainless fasteners through with fender washers, clear silicone, and lock nuts. It's max potential weight is probably 105 lbs.
I can't imagine it weighing more than 75 lbs. including hydrominders and chemicals.
