I have a similar problem and it was due to my motor contactors. One phase wasn't always connecting properly (damaged contacts) and so it would cause the other phase to overload and pop the breaker.
As BigLeo said, contactor would be my first guess. Second would be the motor itself, how old is it? Use your amp meter to check each leg while it's running to see how much each one is drawing.
Because this is a single phase motor the most likely problem is the starter plate / capacitor start circuit contained within the motor. The pump is likely drawing way too much power when it starts. You will likely find that the running amperage is fine.
Your start up current is probably spiking above 20 amps. This typically happens only when the pump starts. You might try a 25 amp fuse. If it holds, then it is in fact your start-up current. You can also check it as suggested with an amp meter.
Might consider cleaning or replacing your contactor and possibly replacing the start-up capicitor.
An amp clamp meter is a great tool to have and not that expensive. With all test equipment, you get what you pay for with regards to accuracy, but in the car wash environment, a $100 model would be able to tell you if you have a problem or not. You just clamp around the wire and read the current draw in amps.
Most multimeters have a 10A Max option. So too low in this instance, but in other instances, you need to change the leads so it's using the 10amp plug-in and put both leads in serial (as opposed to parallel when you take a voltage measurement). BTW, they usually have a separate fuse for the 10A next to the 9VDC battery. If that's blown, you won't be able to measure anything.
Need to get that amp clamp and find out what's going on. What size fuse are you using now? My guess is that the new fuse will only last so long until the problem gets worst and you may cause more damage.
So you're sure it's the pump? Have you had electrical problems that would cause pump damage? Maybe I'm wrong, but it sounds like you're changing it before you've clearly identified the fault. I would check voltage & amp draw at max pressure and make sure that the pump can make the specs listed and that it "sounds" ok (takes 2 minutes). Then I would try to find out why it happened so I didn't install a new pump just to damage it. You right...they are expensive
When you get the new pump, measure the coil resistance and cross-reference it with the one in service. Would be interesting to note.
Tomorrow we'll be replacing the motor for my IBA's Sta- Rite boost pump.
Today we started looking at it to determine steps for removal/replacement.
I expected a spline on the motor shaft but instead found threads.
My original plan was to leave the pump in place and tear the motor off and replace. However, the threads have me wondering if I will need to un-plumb the pump and do the motor removal etc. on the work bench.
Is this an impeller booster pump? (Pump itself is a long stainless steel cylinder). If so, then given the age you probably should just replace the whole pump. At 4 years old, and being disassembled you should be looking at replacing the impeller stack. I'm pretty sure if you add the price of the stack, mechanical seal, and the motor your are at or beyond the cost of a whole new pump. This style of pump can be tricky to rebuild given the number of pieces in the impeller stack. This is just my experience though.
No matter what, you will have to remove the whole motor pump assembly from the machine, and get it to a work bench to disassemble.
Call Dan at Dultmeier and he can get you a replacement pump and motor. Give him the #s off the one you have and he can match it for you. I would also replace the whole thing and not just the motor in this situation. Somewhere in your town or close to it there should be a motor repair shop that could fix your motor or sell you a new one much cheaper than $280.
Took existing motor to a electric motor repair shop and it bench tested fine. Put strain on shaft, still fine etc. Checked amp draw at startup and run modes. Fine w/in factory specs.
Reassembled w/pump (impeller stack, mechanical seal, spring etc.). Fired back up and it runs fine now. Actually had about 15 more operating psi than before we tore it down. (?).
The internal parts looked fine; a bit rusty but otherwise fine.
Now I don't know what to do next.
Have a replacement setup like suggested on hand complete if problem comes back?
