Personally, I would isolate the pickup.Id like to tap into my ro tank to have spot free into my 2 ss bays.
Can i just tee into the line going to the iba or do i have to put its own pickup into the tank.
Also what kind of pump do i need and any other hardware other than a check valve at the hp line.
THanks for that, meter box wiring and place on the dial is in place.Personally, I would isolate the pickup.
Then you need;
* an open position on your rotary dial
* a decal for "spot free"
* a pump (I use a Cat 310) and motor
* a pressure regulator (I run mine between 250 to 300 psi.)
* a relay bank or multiplexer to engage the motor
(here's a thread that may help choose between the two, I've used relays that have been in service for over 25 years)
* single hose running from pump to a solenoid panel
* solenoid panel
* hoses running from solenoid panel to each bay
* checks at each bay manifold
* signal wire from bay box to solenoid panel and relay bank or multiplexer
* checks out at the bay
- I think that's everything ...![]()
What size line from the pickup and what kind of line? Also for for the recirc cant you just recirc it back into the supply line like a cat pump does?I'd get a 240GPH procon pump capable of 250 psi. You could also opt to use a booster pump with similar specs. You also need a regulator, a couple of relays (or a multiplexer), and a line to recirculate from the regulator back in the tank. Use 3/8" nylon (high pressure)line to the bays, and use individual 3/8" solenoids( not a 1/4" manifold).
Yes, that makes it more complicated, as the vast majority of pumps are not suitable for lifting from an underground tank. What type of spot-free pump does your auto use?Oh and the tank is underground, so that will prolly change things
