Spot Free System
benny2
Dallas
I have a 8k gallon per day RO unit from Purclean. I noticed that my unit has only been producing 2 gallons of spot free per minute when it is supposed to produce 5-6 gallons per minute. I tried flushing the membranes with muriatic acid today and that did not work. The unit is only 2 years old. Any suggestions. I am thinking I need new membranes.
What pressure is the system reaching?
Jeff_L
How many membranes do you use? I believe you can expect 1:3 gpm ratio per membrane at 200psi.
1:3 is typical if there's no recirculation of the reject, but it can run 1:1 with.
benny2
Dallas
The system is reaching 180psi the membrane pressure is at 130, and I have 2 membranes
lag
Middle of Iowa
2 membranes to produce 8K per day? if they are the standard size (40x4) you would be at max of 3600 gal per day, or 2.25 per minute.
Jeff_L
From my knowledge bank, at 2gpm spot free with 2 membranes, that's all you're going to get w/o damaging them.
The system pressure and membrane pressure are usually the same, so one of your gauges isn't reading correctly. 200 PSI is the max for membranes, and having pressure as low as 130 will reduce production. Your problem could be a faulty flush solenoid, a mis-adjustment or a failing pump.
Low water temperature will also lower your output of RO. I do not see you getting 8000 gallons per day out of 2 membranes.
benny2
Dallas
Sorry guys I have 4 membranes but my system only has gauges for 2 membranes
jfmoran
PA
How's the feed water pressure to the unit? Inconsistent water pressure or low water pressure will affect the output of the unit.
What's the PPM of the output water of the unit? Is the unit producing Spot Free water or is the PPM on the rise?
If your membranes are bad, then you have other issues. Softener may not be working or chlorine charcoal filter may not be working which is allowing chlorine into the RO unit.
