R rshiggaon Member Joined Dec 18, 2022 Messages 88 Reaction score 15 Points 8 Location Houston, Texas Apr 30, 2023 #1 Can someone help me to share a KR link for this Solenoid? I did find one, but I was not sure if I have the right one. TIA.
MEP001 Well-known member Joined Aug 30, 2007 Messages 16,667 Reaction score 3,937 Points 113 Location Texas Apr 30, 2023 #2 Kleen-Rite doesn't have that exact part. Is that a rinse solenoid on a Coleman Super Saver?
S slash007 Well-known member Joined Jul 8, 2012 Messages 2,412 Reaction score 337 Points 83 Location Lexington, Ky. Apr 30, 2023 #3 This is what you can use instead: https://www.kleen-ritecorp.com/p-91...e-1-2-in-24-vac-metallic-conduit-housing.aspx It is for a Coleman Stand it seems. They also sell repair kits if you just need the diaphragm.
R rshiggaon Member Joined Dec 18, 2022 Messages 88 Reaction score 15 Points 8 Location Houston, Texas Apr 30, 2023 #4 MEP001 said: Kleen-Rite doesn't have that exact part. Is that a rinse solenoid on a Coleman Super Saver? Click to expand... Yes you are right! It's used for the RO. Attachments Screen Shot 2023-04-30 at 10.12.04 PM.jpg 42.3 KB Views: 12
MEP001 Well-known member Joined Aug 30, 2007 Messages 16,667 Reaction score 3,937 Points 113 Location Texas Apr 30, 2023 #5 It's not what I thought it was. If it was for the cold water rinse, I would have an alternate valve suggestion. Is the valve bad? There are repair kits. If the coil is bad, any 24V AC coil of that brand and type will work in its place.
R rshiggaon Member Joined Dec 18, 2022 Messages 88 Reaction score 15 Points 8 Location Houston, Texas May 1, 2023 #6 MEP001 said: It's not what I thought it was. If it was for the cold water rinse, I would have an alternate valve suggestion. Is the valve bad? There are repair kits. If the coil is bad, any 24V AC coil of that brand and type will work in its place. Click to expand... The coil was bad. I want to keep a backup (valve + coil) just in case I need it in the future. This solenoid is used to turn on the backwash of the RO system.
