Wayne J
I've been having a problem with a white chalky build up in the inlet side plumbing and in the heads. I've been told it was because I was mixing the soap too strong. I've diluted the mixture some. Haven't had any customer complaints so far.
Anyhow I have a head that I need to remove a valve from. I can't get the valves out because of the build up around the valves. What is a good way to remove this build up?
Thanks,
Wayne
Thanks,
Wayne
