Yes I am going to get them custom made, I am just not quite sure how to word the signs, since it isn't up and running yet. Nayax doesn't have anything. UGH.Your going to have to have them custom made. Any fast sign outlet should be able to make them for you or a local sign shop. Post some pictures of your install. I've seen USA Tech card readers in the bays years ago but have seen Nayax yet.
You can always post your ideas here and get suggestions. It would help to know how Nayax works too. Do you just swipe and wash like Cryptopay or do you have to select an amount you want as credit on the timer?
VPOS touch- getting installed right now. Yes it is installed on the box.Interesting. Which model Nayax card reader is that? Have you got one installed in a coin box yet?
Interesting. Is this the unit your installing? https://www.kleen-ritecorp.com/p-65...b-touchscreen-cash-free-payment-solution.aspx How much hardware goes inside the coin box? Can you post a few pictures?VPOS touch- getting installed right now. Yes it is installed on the box.
i had it on my old standard gxp and all that you needed was the cell modem and the payment head. the cable attached from the modem to the mdb plug inline.Interesting. Is this the unit your installing? https://www.kleen-ritecorp.com/p-65...b-touchscreen-cash-free-payment-solution.aspx How much hardware goes inside the coin box? Can you post a few pictures?
The rotary switch STOP decals will soon be replaced with OFF decals...thanks Mep001.
Or even "Pause".What about naming it "neutral"? It is something that lately I have been thinking of calling it.
"Pause" is pretty much the same as "STOP". This kind of goes to show you how the public thinks.Or even "Pause".
I would use "Idle" instead, but IMO "Off" makes more sense.What about naming it "neutral"? It is something that lately I have been thinking of calling it.
If I were to see "Pause" on the switch, I would think it would pause the timer.Or even "Pause".
Which is why I made it work that way on the first CC system I had my hands on.I get calls every now and then from a PO'd customer who thinks that when they put the rotary switch on "STOP" the timer should stop counting down.
