Sealant LED on Razor Instructional Sign.
water guy
My LED light is not coming on for the Sealent in the bay.Has anyone seen this before?
Blanco
If you know how to use or own a multimeter, PM your number and I can help you troubleshoot.
The problem is either:
1. Bad ballast (if applicable)
2. Bad LED light
3. Bad output card (rare)
4. Loose or broken wire
5. Bad relay (if applicable)
water guy
2. Bad LED light
I appreciate the help.
water guy
I went to the wash today and checked the outputs and there changing color from red to green. But I didn't check to see if I'm getting 12vols to LEDS. Went looked at the box on the back of the sign and all of the heads on the plastic screws are gone. Hopefully it's dry in the box I'm gonna get some more of those screws first.before I open it up.
