Scotch Plaid Hyrominder Tip Ratio Chart
Thanks Bill. KR acualy had some made as mgnets. Told them it would be great if they also listed the ultra lean ratios. They said maybe when the exhausted the current batch.
termn8tr
Windsor,Ontario, CANADA
Metering tips for Hydrominder 511
I have misplaced my chart and I can't remember what color tip is 1/2 an ounce and which tip is 1 ounce.
termn8tr
Thanks David, however I must have had a different chart. This one doesn't tell me the # of ounces applied with each tip. Would you by any chance know.
Thanks
DavidM
PA
I don't have chart that shows that. It would be specific to your equipment and how you are applying the product. The hydrominder controls how much concentrate you are getting to water. A purple tip at 1:120 is very close to one oz per gallon of water (1:128) and a pink tip would be about 1/2 oz to 1 gallon of water. Do you know how much diluted product you apply per car? You could calculate the tip size needed with that information.
termn8tr
Thanks David I placed the purple tip on and it's working out great. I was putting way to much on before with the red tip. Thanks again
JIMT
Toledo, Oh.
termn8tr,
This is what I use.
HYDROMINDER TIP CHART 11/22/06
TIP COLOR WATER TO SOAP RATIO PERCENT SOAP IN SOLUTION PERCENT LESS SOAP IN SOLUTION WHEN GOING DOWN A TIP SIZE PERCENT MORE SOAP IN SOLUTION WHEN GOING UP A TIP SIZE
NO TIP 4 20.00%
16.67% 20.00%
GRAY 5 16.67%
14.29% 16.67%
BLACK 6 14.29%
22.22% 28.57%
BEIGE 8 11.11%
BAD CHANGE HERE 50.00% 100.00%
RED 17 5.56%
25.00% 33.33%
WHITE 23 4.17%
7.69% 8.33%
BLUE 25 3.85%
29.73% 42.31%
TAN 36 2.70%
24.49% 32.43%
GREEN 48 2.04%
24.62% 32.65%
ORANGE 64 1.54%
14.47% 16.92%
BROWN 75 1.32%
16.48% 19.74%
YELLOW 90 1.10%
24.79% 32.97%
PURPLE 120 0.83%
BAD CHANGE HERE 49.79% 99.17%
PINK 240 0.41%
JIMT
