Clean the photoeyes at the front of the bay that activate the rocker panel blasters then run a vehicle through and see if it clears itself out, I used to get these after I was working in front of them or just standing in front of them for a few minutes.
Check the inputs to the PLC, pull the arms in and out to see if they the input lights make a transition. It could be a air solenoid if the arm is not coming in during the wash.
We have been receiving the #25 error (Arm prox) for several days now. But, it will work fine for a number of cars and then it will error out after turning to go down the drivers side for the first time. All the prox switches are lighting up when the arm rotates.
No, he doesn't but I do, I had him put a call into Ray for some "over the phone" advice, I stopped by to see what was going on I manually put the arm in the middle of the bay and rotated to the "forward" position and it spun 360 degrees but the proper proxes are lit up when it's in the 90 degree position at either direction for the wash process and his d timers are all ok, so I am waiting to see what Ray has to say before I try anything else.
Sorry it took so long I have been very busy. These codes indicate the plc was turned off or the PLC's internal power supply is going low. These PLC's rarely go bad, but I have seen them loose power due to a shorted input. It would be hard to find if it is only intermitant. Are you still having problems?
