robblackburn
Anyone familiar with the Ryko thrust pro dryer? I am having trouble with mine not turning off and continuing to run. It is my understanding that inside the PLC of the dryer there is a maximum run timer that should turn off the dryer after set amount. My dryer works with two loop detectors. If the loop detectors find the vehicle properly then everything works fine and the dryers shuts off when vehicle exits. If he vehicle pulls into the dryer area early then the dryer will continue to run. Any help is appreciated. Thanks.
Rob
Rob
