bneckrock
Bill Neckrock
The seals on one of my Sta-rite Boost pumps are leaking, I have the seal kit. My set up is as follows: Water enters a pressurized tank, the boost pump delivers water from the tank as needed to the holding tank on my OHD pump stand. The High Impact pump delivers the water to the bay. This is the water used for the High Impact (HI) rinse function.
My plan is to turn off the water supply to the pressurized tanks, disconnect the power to the Boost Pump and then run the HI until empty, replace the seals and put everything back to normal.
Does this sound like a plan that will work? Has anybody replaced a similar seal kit? Any problems I should anticipate? Thanks for any input.
