Ryko Softgloss with Unitec
trentu
Oklahoma
Just put in our first Ryko softgloss with the Unitec wash select II. When the Ryko takes a fatal error like tripping one of the motor overamps it does not put the wash out of order on the Unitec. Is this possible? How would we do it? Thanks
Russ
pitzerwm
Tri-Cities, WA
You might be able to take a signal off the Ryko PLC and send it to the "down" signal on the Unitec, or using a small PLC to monitor all of the important signals. I would surprised that any time the IBA shuts down it doesn't trigger the Autocashier.
randy64
Des Moines
They could be using wire 28 (in use) if so switch to wire 92 (input inable). If you can't get let me know and I will give you my number.
