Running board Tower spray nozzle size
APW
South
I had some custom stainless steel towers made with two tips per Tower angled down to blast just the running boards on vehicles. I am unsure what tip sizes to use. It will be a cat 3535 pumping the water. What size tip would you recommend?
Eric H
Leominster, MA
Does this run at the same time as the power towers and undercarriage? If not, I’d be afraid that there wasn’t enough water flow.
APW
South
These will take the place of the power towers and tied in with under carriage. Want something with not that wide of a fan.
Eric H
Leominster, MA
My newer undercarriage has 5 nozzles. The 3 middle are pretty wide and the outermost nozzles are narrow. I’ll try to check the size on them tomorrow and send a picture.
  • Like
Reactions: APW
On my Mark VII’s I had either #9 or 10’s in the UC. There were only 7 nozzles If I remember correctly, but I was pumping with a much smaller pump. It was very impressive to hear underneath the car. With a 3535 you should be able to put pretty much anything in there. Go big or go home.
  • Like
Reactions: APW
