toddmullens
Any suggestions on a particular brand or model of rotary laser or another tool or method to simplify the process of installing a set of drive rails perfectly level?
Most tool rentals have 'em.Any suggestions on a particular brand or model of rotary laser or another tool or method to simplify the process of installing a set of drive rails perfectly level?
Does this same method apply to installing rails on the floor that must be perfectly level with each other? I can’t visualize it in my mind. I can see how it would work with mounting to a wall but not the floor.You can use the method that the ancient Egyptians used thousands of years ago. I’ve used it many times. Simply get a piece of clear soft tubing and mostly fill it with water and a little food dye. Mark the tube ends about 4 “ from the end. Put the ends on the wall and mark the water level. Move the other end around the bay and mark. You now have a perfectly level guide to set the rails. BTW the pyramids are still standing after 5,000 years.
