sudsurfer
Anyone have any ideas on capturing r/o reject water that is just going down drain. How to, and what uses?
My storage tank is lower than the HP tanks.Capture reject water into a storage tank. Place the storage tank near and above HP rinse tank, If you have another welded threaded coupling port, plumb the storage tank line (Gravity fed) to the tank. Use a float valve and adjust it to turn on slightly higher than the other float valve.
