RainX Application
anyusufaly
Yusufaly
Hey everyone. I wanted to find out what you think the best application method for RainX is in order to give the best show and have the highest purchase rate, but still keep chemical cost reasonable. I currently have it set up through a standard arch with k-nozzles and a RainX sign to the left of the vehicle that lights up. I was thinking about changing out the arch with a TSS Nova arch that lights up and then maybe doing a yellow LED light bar. Not sure if I would apply via k nozzles, waterfall method or a foamer via rain bar. Would really appreciate any help. Thanks!
I run it the same way you do!
i include it in my top package and rarely sell it ala carte. Are you going after the wow? I was told that using the foamers would cost you alot more in chemical use.
Just a fyi!
Thanks! I know that my chemical cost will go up with using a foamer, but if I can get a better conversion rate to my top package, then it might be worth it. Problem is that it is an expensive experiment to try out. So not sure what to do.
I don't know why adding a foamer would increase costs. Foam ads air and creates more volume with foam as opposed to straight liquid. Air is cheaper than solution. My K nozzle sticks have foamers at the top.
Correction: I also have foam generators on my k nozzles for rain X. I forgot to include by using shower heads along with foam generators, you will be using a lot of chemical.
