Questions for those with a Washworld Profile
Lexington, Ky.
I plan on putting in a Profile to replace my Soft Gloss ( and to match my Razor) and had a couple of questions I need to figure out before I order. My distributer sent me this to think about and I wanted to get feedback here "
We put it on the first profile we did last year but found that we had a very hard time rinsing it off the vehicle with the Profile
machine as compared to a Razor mainly because Razor goes around the vehicle and is able to rinse more completely. We did not order triple foam for the most recent Profile that we just installed and instead used Foam N Flow like the rain style and are happier with it because of rinsing much easier."
Any thoughts on the TF on the Profile and rinsing issues?
2nd, anyone here have Spectra Ray on their machine? I opted out of it on the Razor and put 2 long light bars on the walls which works great, but wondered if I would get the same effect on the Profile since it would have actual brushes on the side that might obstruct the view. Spectra Ray + is an extra $4500 so that's out, but I need to decide between the original Spectra Ray or using TSS light bars.
Thanks!
washnshine
NY
Thanks!
Two things:
1. Don’t know anything about the Profile but I give credit to your distributor for being upfront and honest about what he is seeing, rather than just loading up the machine with options and then having you have to work around some issues. They don’t all do that.
2. Triple foam can probably be done without. When it came out in the 80’s/90’s or whatever, it was the newest extra option up sell and was reserved for the top packages. Now, there is so much lights, colors, lavas, waxes, foams, foaming walls/waves etc., a traditional application of triple foam can probably be done without in terms of function and show. Especially if you are getting a new machine. The customers will have never had it on that specific machine and probably won’t miss it. I’m sure you’ll have plenty of “show” and results to justify whatever you are pricing your wash packages at.
Lexington, Ky.
I definitely appreciate him being up front about it instead of just trying to sell me the option. Would be mentally hard not having TF on an IBA lol after all these years. I wouldn't miss the 3 less barrels in the ER though.
Surely some "Profile" guys on here have opinions on this. CheetahWash needs to chime in
CheetahExpress
Mathis, TX
Yes, I'll chime in. We put in a Profile-Max in 2018 and loaded it with everything -- Foam and Flow and Triple Foam. Yes, we occaisionally have customers complain that the foam is not rinsing totally off their vehicles. It happens only occaisionally and does not appear to be a continuous problem. The customers LOVE the triple foam. It is only offered on our top wash, The King Cheetah ($13), and 65%-70% of customers buy that one. Our ChemQuest Triple Foam products smell like berries and they also provide a bit of polish, unlike many other TF products that are just color and smell. Sometimes Mother Nature affects the rinse cycle -- if there's a wind at all, it will blow through the wash bay and separate the rinse as it comes down on the vehicle, and the vehicle will not be rinsed completely. If we get several complaints at one time about the foam not being rinsed well, we get our distributor down here and they check it out and adjust it. I'm not a mechanic, and leave it up to them because we have a maintenance contract with them. Hope this helps.
CheetahExpress
Mathis, TX
Thanks Cheetah, good information. Do you have Spectra Ray on your unit by chance?
No, we don't have any of those fancy lights. Also, I was just chatting with one of the WW techs who's at our wash installing new hoses and asked him about problems with the rinse system. He mentioned a couple of other things I didn't put in my last note: 1) Some of it might also have to do with the actual configuration of the vehicle -- I know my Cadillac XT5, due to the "visor" that sticks out from the back of the roof, will sometimes keep foam from rinsing off, which is a common problem with alot of these SUV's and Crossovers; 2) after the TF application, there's a Sealant application that comes out of the Foam&Flow followed by another rinse and the RO Spot-Free Rinse, and sometimes that's where the Sealant sometimes stays on. The Rinse can be made to go "slower" to get a more thorough rinse if you are having a problem, or maybe turn up the pressure on the rinse before the Spot-Free.
Lexington, Ky.
Appreciate you asking. People here love the lights, so I wanted to add something, but think I may stick with the TSS LED bar as it will just cost me $1900 vs the $3500 for Spectra Ray and it should offer more light.
Makes sense about the different cars possibly being an issue. Currently on my Soft Gloss, TF comes on first and is used as lubricant I guess for the wash packages that get it. Since it's first, it is always rinsed off. Using it as polish it would have to come on at the end.
Finally, do you have the touchless wheel cleaner? If so, how do you like it? Might have already asked you in a previous thread but couldn't remember.
Thanks!
CheetahExpress
Mathis, TX
Thanks!
Yes, we have it and it is offered in the middle and top washes. Customers use it alot -- we're in a South Texas rural community -- many farms, ranches, oilfield, construction, hunters -- lots of dirty pick-ups. It does a great job, but you need to make sure you're using a real good strong alkaline cleaner. We use ChemQuest Select 35. But be advised there will be some maintenance involved -- high-pressure hoses, bearings, spinners, etc. due to the constant wear and tear. We also have the Power Tower and Undercarriage wash, which I can't recommend highly enough! It blasts off alot of the road grime before the vehicle even gets into the wash position. We plan to add another bay and install a Razor next year, and will have the Power Tower with it also, as well as the Foam&Flow and TF. Will offer the same pkgs. as we have with the Profile-Max with same pricing just to eliminate customer confusion.
Lexington, Ky.
Really appreciate all of the information. I have the Power Tower on the Razor and it does a great job. Another reason for this upgrade is to keep everything consistent among the two washes.
Thanks!
Why don't you put TF toward the front, & use it as a lubricant. You already have F&F & a,Sealant, so your TF is a 3rd similar product, & thus just redundant. Put it on early & seems problem solved + xtra lubricant, which is better longterm for the brushes.
Do most owners buy the standard razor or the edge model? I'm assuming the difference is mainly visual enhancements, and performance enhancements in the edge?
By the way, even though triple foam is old school, getting lava to sheet consistently is a royal PITA on a lot of equipment. I know on my machine you can get it sheeting good then come back in two days and it's not sheeting good anymore. Plus it's very vulnerable to wind. Using Expensive premium products sealants (carnuba or "ceramic" products) in this application cost quite a bit and results in an uneven application to the car's surface. I would only use lava for a shampoo or the older traditional sealants.
Lexington, Ky.
The Razor Edge includes all options offered, but you can get the standard Razor and all items ala carte. I didn't need the Hyper Flex, so I just bought the standard Razor and added the Lumen Arch, TF and Lava.
Btw, I knew getting a curtain and keeping it consistant was very hard, so I just had them turn down the air and use it Rain Bar style. Looks and works great, and zero tinkering! I was the first one they installed that way, and now they recommend it to their other customers.
APW
South
Slash what kind of product do you use through the rain bar/FnF? I was using carnuba wax through the Foam n Flow and had uneven applications and streaks on the side of vehicles so I just switched to a different product through the Foam N Flow.
Lexington, Ky.
I'm using Warsaw Chemicals Wave Shield. It's Formula 704. Says Hot Carnauba Shine on it.
  • Like
Reactions: APW
I use Quest "Shine On" through my ColorWave, & it is awesome! Not an even sheet, but it covers good once it gets on there.
