bigleo48
All,
I have a M5 and the 3x foam is a pain and delivery is very finicky as their are many very small orifices in the system. My main complaint is uneven chemical dispensing. So I was thinking that perhaps installing a tipple peralistic pump to feed the chemical into the injectors. So basically, the M5 setup remains the same, but I remove the white tip of the injector and install the pump between the chemical tank and the tip less injector. That way I can ensure that all three colors are dispensed the same.
This is the pump I'm thinking of using http://www.kleen-ritecorp.com/p-18813-triple-head-pump-system-14.aspx. Not cheap at almost $500!
Any comments?
Big
Any comments?
Big
