Pump Oil Changes
Kirb
_
How often do you chance your oil in IBA, SS, and compressor pumps?
How high in the sight window should the oil be? I have been keeping it just above the dot so about 5/8 to 3/4 of window is filled, but not sure if this is to high and could cause possible damage.
Thanks,
Kirb
lag
Middle of Iowa
I change yearly in the fall.. If you have a sight glass with a dot , just keep it to the center of the dot(that is considered full)..
