Pump Motor Stalls
pjk4370
australia
Hi Guys , Iam installing a new pump setup for my new manual bays . When i turn the pressure up above 800pdi the motor stalls .
Iam using a cat 310s with a 2.2kw motor the same setup in my existing bays . Its got me stumped any ideas
pjk4370
australia
Are you running it that speed with a VFD? It should give a fault code.
PaulLovesJamie
rural 5 bay SS
Kutztown PA
what do you mean by "stalls"? It completely stops? Or it stops intermittently?
Thermal overload tripping?
amp adjustment on motor starter not set right with higher draw?
Loose wire somewhere?
pjk4370
australia
Motor starts to slow down when increasing pressure over 800psi ... overload hasn’t tripped as I decrease pressure ..... checked voltage when motor starts to stall 410 volt between phases and current is 5.2 amps which is full load of motor
By the way iam in Australia and we have 415 3phase here
PaulLovesJamie
rural 5 bay SS
Kutztown PA
Sounds like my old truck going up the mountain with a load of firewood :)
I'm not the best person to comment on this, but maybe the 2.2 kw motor might be too small to handle the load? (2.2 kw = 3 HP)
I think most of us use 5 HP with cat 310s... well, I do anyway. Depending on how much water you're pushing at what pressures/tips/hose diameters, maybe the motor cant handle it?
