Pulsing flojet
You will see something running in the bay if it's a solenoid. If you don't, it's the pump failing or it has trash in the valves.
What you could do is install a ¼” solenoid valve on the air line going to the Flo-Jet pump and build a relay bank to control the solenoid valve. For a 4 bay car wash a relay bank would be simple to build.
