Probe style low water cutoff...
Twodose
NE Pennsylvania
Anyone use a probe style 24v low water cutoff on there boiler for the in bay hot water wash and rinse.
Taco makes a couple different model's but I'm not sure which to use.
The line on the boiler that the switch is located is 2".
I have been using the watts fs-10c paddle type and I can't get 2 months out of these new ones that are made in China.
I know your supposed to have about 20" on either side of the switch but I don't have that option.
robtl
central Ky
central Ky
Would it not be better to use a flow switch on the hot water boiler ?
OH NO, I reread and forgot about flow switch you were already using with problems!
Twodose,
I don't know if they have improved their product any but we had three Honeywell electronic low water cutoffs for our boilers put in about 20 years ago & our experience was not good. They were expensive & they would go out just after the warranty was up. We went with the McDonnell Flow switches because we already had good experience with them.
We did have a one time event flow switch paddle break causing a major problem with the paddle plugging a hard to get at circulating pump. Our solution was to use the upper part of a spare paddle or two to beef up that part of the metal that broke. We verified with a Gerand Valve & Gerand Flow Meter that the valve was still functioning properly & within the proper range.
