PDQ Virtual Treadle
stud
Florida
Does anyone know what would cause a "Measure Eye" fail on a Laserwash virtual treadle setup?
madscientist
Austin
Is it happening all the time, or just after a reset?
Either way, it happens when the arch in home position is not all the way to the right (pressed into the dump valve).
Mike
Green Bay
If you have a treadle, the measure eye is not seeing the reflector plate when dumping.
If you have a Virtual Treadle check your right side ultrasound sensor and make sure its working.
Easy way to do this is to just sit between them and listen to make sure both are clicking.
If not, replace. If it is clicking turn dial in vt to position 1 click cw from home (where the led's scroll) and see how many leds are light up, each led is about 17 inches of distance to what ever target you have in front of sensor.
hope this helps
Mike
pmedasie
Claysburg PA
We had the same problem and found it to be the ultrasonic eye. Replaced it and it fixed the problem.
Ours was going too far away from the back of the vehicle.
