they dont list a #30
Bay Error Text
1: Fuse Blown
Displayed during each star-up sequence, or power is off to pump node.
2: Disable Outputs Active
This is displayed during each star up sequence.
135: No Comm Buffer Err
Node chip is corrupt.
136: RS 485 Timeout
Width Sensors disconnected or incorrectly wired or failed.
137: Disable outputs true
Will be seen at start up, or when ever voltages on back plane not right, output card shorted, or back plane shorted.
138: No US Sensors
The width sensors were not found. Loose wires or bad sensors.
139: Too Many Sensors
Too many right or too many left USS‟s
140: No Comm
No communication to the USS‟s
141: Bad Timeout
Communication with sensors timed out. Bay Warning Text
1: Reset
2: Default Rack Config
3: Default Constants
Seen at startup, means the node is initializing
4: Wrong Table Length
Only at startup, means the node chip is corrupt
128: Bad Measurement
Width sensor measurement that is too short or too long.
129: Bad Temperature
Abnormal temperature received from width sensor. Bad sensor.
130: Bad Response
Communication problem with width sensors, check sensor and wiring.
142: Wrong State
Corrupt node chip.
143: Dipswitch Setting
Corrupt node chip.
255: Unknown Cmd
Means communication with conductor or node chip is corrupt.
