PDQ Access To Ryko Softgloss
NJWashing
New Jersey
Looking to see if anyone has done this. Having a problem getting the wash busy/inuse signal to work properly. Tried several different options, no luck yet. I'm able to have the wash busy to come up on the Access but it drops that signal as soon as the wash ends and then sends the next wash while the other car is still exiting the bay. Thanks
Mike
Green Bay
Please give up a call at PDQ tech support, the Access can function in several different modes, it may be just a programming issue.
We have hooked up Access units to several Ryko in bays and they are running, some units required relays to get the signaling set up correctly.
We would need you to understand exactly what is required from the softgloss unit for timing with the wash in use and wash request signals to figure out how to make the access work with your machine.
Regards
Mike
