I hope you're still on this site. I have been following your responses and have found you to be one of the most numbers based individuals out there.If the project is being benchmarked as in concept planning, then applying an operating expense ratio of between 45 percent and 50 percent against gross sales would be appropriate.
He was banned years ago.I hope you're still on this site.
Does the 45-50 percent estimate cover fixed and variable expenses? I realize a proforma would give a more accurate picture with real numbers, but I received a proforma that listed $34,623.65 per month in fixed costs alone. I may be completely naive, but that seems astronomically high.
it really depends what is considered fixed vs variable. In car washes almost anything can be variable. It also depends if this is EBITDA or cash flow. Lastly, what is the volume for the month of $34k fixed expenses? My guess utilities are counted as a fixed expense in the $34k which would make sense of the number
40-50% is good but you can be successful at a much lower number. It just depends what your goals are (ie volume approach vs ticket average approach) and what kind of business you are (ie. Do the minimum or wow all your customers).
