Not getting pulse from Nayax reader
rikvending
Hello All,
I just set up my first Nayax card reader on self service car wash machine. My timer is Dixmor LED7. I connected Pulse 1 wire to white wire with black stripe on #9 pin and when I use my card looks like my card is getting charged but card reader is not sending pulses to the timer. Any idea how to fix this issue?
Thank you
Hello All,
Thank you
One thing I learned from recently installing is NOT to use the pulse wizard on the nayax dashboard. Support even tells you not to use it, which is a bit odd.. If you already did use it, I would just call support and theyll have you set up in no time. Ive seen some comments about bad support but to be honest ive called like 6 times and there extremely helpful. They even helped get my custom picture for my idle screen working !
Also post your firmware of your dixmor 7 timers, may be helpful to people in here offering assistance. Just power off the meter and when you power it on again it will flash on screen
Pretty sure you have to have an interface relay for count down on a nayax dixmor setup. There are many posts on here on how to properly setup the hardware side for nayax install. You will need a low level relay, readily available on Amazon
Count down
Do you know how to wire low level relay to dixmor led7 timer? Do I need 12V or 24V relay?
Thank you
Check this thread out, has all the info you need.
