I thought I give you a bit of an update on my mysterious
drying problem. This is what I found out so far. We recycle the water. When I switch over to fresh water instead of using the recycled water I don't have a
drying problem. It is all normal. If I switch back to recycled water the problem comes back slowly when water quality gets worse. Although I rinse the cars off with RO water there seems to be a relationship between using fresh and recycled water during the brushwash. Strange
Nothing strange about it. Most reclaim systems will eliminate entrained oil but virtually all reclaim water contains some amount of emulsified oil, the amount of which will vary considerably depending on the quality of the reclaim system and type of processes employed. Generally speaking, as the level of emulsified oil in the product water rises, the likelihood of dirt being redeposited on the vehicle rises. Dirty "clean" vehicle equals difficult
drying. Adding RO on top of a dirty vehicle will only make
drying more difficult.
My question is why does the quality of the reclaim water become worse?
My guess is you have one of those little in-bay systems with a hydro-cyclone, two bag filters and two small (undersized) underground settling tanks. If so, what usually happens with these systems is that the tanks are not large enough to allow adequate precipitation of particles. Over time and as wash volume increases and/or the filth level of vehicles increases, the particle content and emulsified oil clogs up the bag filters. Once clogged, the water pressure tends to drop but, more importantly, the quality of the product water will degrade significantly.
Jerking around with chlorine and other band-aids solutions for reclaim problems usually just complicates matters.
My suggestion is to bring a reclaim expert to the site to analyze your situation and get to the root cause of the problem.
