I searched this topic and could not find any answers to this question..I am not getting any soap in bay 4(all other bays have soap) I set it on wash and all i get is high pressure water no soap at all. Any suggestions??
Did you check voltage on the coil? and take the valve apart to check for a blockage? Sometimes I just take the poly tube off of the valve outlet and turn the bay on soap. If soap trickles out it usually indicates that there is voltage but there still may be a slight blockage.
What timing for this topic! I'm having the same issue with my bay 4 as well. Troubleshot it all weekend (between busy times) and have not figured it out yet. I use a low pressure regulator to draw in the soap, which is usually the culprit when I'm not getting any soap. I've replaced that, the solenoid for the soap, and the check valve to the low pressure regulator. I get a quick 2-3 second burst of soap at the beginning, then nothing. My next step is to looking into the two valves (hot & cold) which feed the pump to see if one of them has gone bad.I searched this topic and could not find any answers to this question..I am not getting any soap in bay 4(all other bays have soap) I set it on wash and all i get is high pressure water no soap at all. Any suggestions??
