no soap in bays high pressure low pressure
vinetta1
wv
Not getting any soap in bays in low and high pressure. Have a dosatron system. anyone familiar with this . use liquid soap
DiamondWash
Des Moines, Iowa
Check the foot valves in the soap containers make sure soap is in the line feeding the dosatron systems.
Is there just one Dosatron pump that supplies soap for both the low- and high-pressure? It could be a problem with the Dosatron or its foot valve. It would help to know more about your set-up and the manufacturer.
In the past I have had this type of pump lock in between the stroke where it switches from up to down. Unscrew the top and manually cycle the pump down and up a couple of times. Screw the top back on and it should work. You should hear a clicking sound if the pump is working properly.
