New Lighted Keypad for Retrofitting a ShurVend
Uncle Sam
We have been asked in the past years if the keypad could be lighted; we have always had to tell them no. Now we can say “yes” to all customers. As we recently posted AMS has developed a new vendor style called the EPOCH which is now in production. The lighted keypad is numeric and only works with the S-3 control board and Version 1.35 software in the Epoch. All the older S-1 and S-2 control boards will not operate this lighted keypad, but we have developed Upgrade Kits for all these older vendors. This change over may look complicated and difficult, but we include step by step instructions in the Upgrade Kit for you to follow.
O.K., as a ShurVend owner, how do I find out what software I have in my machine? Easy to do. Turn the power off to the vendor and then turn it back on while looking at the display on the front. The first thing that appears is the Sensit I, Sensit II, or Sensit III designation with the version appearing after that. Now that you know the Sensit number, we need to know whether your machine is Alpha-Numeric (Letters and Numbers) or all Numeric (Numbers only).
If you have a numeric vendor, which includes all ShurVend Junior RL & FL and the VendPro-iG4’s, the upgrade to the lighted keypad is relatively easy; install a new S-3 control board (We will program the control board options and a $1 price on each column) to replace the S-2 one, remove the mask and/or escutcheon, replace the old keypad in the escutcheon with the lighted keypad, re-install the escutcheon and mask on the door, configure the motors and change the pricing of your products that are different than
$1. You are good to go. Cost of this Upgrade Kit for an S-2 vendor---$425. Cost of the Upgrade Kit for an S-3 vendor (Mostly recent refurbs and the VendPro-iG4’s)---$125
Cont'd
The ShurVend Junior RL & FL and VendPro-iG4 vendors Upgrade Kit will be very similar to the Numeric vendor, but the procedure and parts will be different and the lighted keypad has a different hole pattern. Again directions will be included in the Kit. Cost of the Upgrade Kit for an S-2 vendor----$425. Cost of the Upgrade Kit for an S-3 vendor--- $125.
For those of you with Alpha-Numeric (Letters and Numbers) keypads, it will be a little more complicated. The ShurVend Upgrade Kit for the older S-1 Alpha-Numeric vendors has all the parts needed to convert the vendor to a numeric vendor: new S-3 control board, new Sensit system, new digital display, new escutcheon, a new numeric mask, new numbers for the tray fronts, and the lighted keypad. Cost of the Upgrade Kit for an S-1 Alpha-Numeric vendor---$875.00
If you really want to upgrade your older machine so it has the same equipment as a new vendor, you should consider installing the new LED lights in place of the fluorescent lights you have. You can do it at the same time as you are doing all the work for a lighted keypad. Cost of the Upgrade Kit for an S-1 Alpha-Numeric with LED lights---$1175
For those of you who want to consider any of these upgrades for your vendor, please email or call us with the vendor serial number, Sensit Number, and whether you have an Alpha-Numeric or Numeric keypad.
Uncle Sam :)
559.901.6452
jimholve@big-eagle.com
