Good Day, I am looking for a more optimal set up with the cat pump, I feel mine is using a lot of valves both internal and external. The setup is: bottom left inlet is a tee hose from the unloader (balance pressure regulator) and city water supply, right is from the Erie 3-way, the right outlet is a tee the weepmizer the pulsation dampener, and hose to bay, left outlet is tee to pressure gauge and another tee to spot free with check valve to balance pressure regulator the incoming water goes thru a Dema 443P.3 NC 3/8" Diaphragm Valve with EPDM Seal and 24 VAC Spade Coil. Here are a couple pictures. Any suggestions?
