Need opinions on my Cat 3535
QuickshineCW
Just looking for opinions on what direction I should go. My auto uses a 3535 but I am only able to get about 850psi max on each arm and it usually was around 1200. It is making a weird stutter while running too. I put a new unloader, new nozzle kit, and inlet check valves. I'm getting a good supply of water into the pump. I did the check valves without removing the pump from the pump station so I couldn't get a real good look inside but I could see some washout behind the valves. My question is do I try to rebuild for another $1200 in parts or play it safe and spend the $5000 for a new unit. This pump has 180,000 washes on it.
