Need Nayax Machine installer for Vac Bays
miamicarwash
I own Miami Car Wash in Houston. I have 8 vacuum bays that I need Nayax credit card readers installed. Most have been mounted to the bay, but not wired to pulstate the machine. The vac bays vary in models. Does anyone know anyone that can help? image0.pngimage1.png
Thanks for the response Keno. We are having an issue with the vac actually turning on when the time starts. Any suggestions on installers to do the wiring?
I don't know any installers, but maybe able to help you out. Are you doing count up or count down? Both can be achieved with a cheap low level relay from Amazon. Count down would just send coin pulses to the current timer. Count up would be a little different, but still relatively simple
Thanks for the information. We have a count down timer. FYI...this is my first car wash and "simple" will most likely be a difficult job for me. haha.
In that case, all you have to do is setup the nayax with the Amazon relay to send pulses to the vac timer, just like a coin acceptor does. I tap into the same line from the coin acceptor that sends the pulses to the vac timer with the relay from the nayax. Who installed these nayax units for you? Can they help you with the wiring?
Thank you so much for the information. Can you please provide a relay you would recommend from Amazon? We had a local tech company attempt to install the readers, but they ended up throwing in the towel after mounting them and attempted to wire them a few times. I have been having a very difficult time finding anyone to complete the job.
We use these relays in low level mode and the ac/dc converters to convert 24vac into 12vdc to power the nayax and the relays. I think I may have a generic wiring diagram to hook up to vacs, I'll take a look on my computer. Hopefully the local tech company would be able to look at that and figure out how to finish the job. I'm curious as to why they took the job if they didn't know what they were doing?
Thank you for the links. The techs that came originally had no clue what they were doing. Still looking for someone to complete the job. Where are you located? Do you know of anyone in the Houston TX area?
