Need a PLC
APW
South
I need someone smarter than me to help me figure out what PLC I can use to control a speaker. I need one with at least six outputs and ten to twelve inputs. On the output side I would need to be able to energize four to five of the outputs at the same time. The outputs and inputs would be 24 volts DC. Thanks!
Blanco
What are you trying to accomplish? Why do you need a PLC?
APW
South
I want to use it to send 24 volt DC signals to activate a speaker. Some of the voices take four of the outputs on at the same time, some take two or three. I did it with relays but I would like to try it with a PLC.
I'm fairly familiar with a ladder relay. The one I've used has 8 inputs and 4 outputs, and there are modules to add more outputs. IMO if you can do it with relays, you might as well do it with relays. The ladder relays will cost you around $300 to get 8 outputs and the software is a very steep learning curve beyond just dropping in very basic functions. Combining outputs from different inputs would be very easy.
Have you looked at the PLCs by automationdirect.com? They are a legit big company in Cumming. I went to a PLC class there about 15 years ago.
APW
South
Thanks, I'll check it out.
John J Spokas
Naperville, IL
It is definately easier to do this with a PLC once you get past the learning curve for programming.
  • Like
Reactions: APW
APW & others,
Whether you are going to a PLC or just settle with your relay approach ... it is IMHO a good idea to separate all of the distinct voltage circuits on a basic ladder logic diagram. That just consists of simple rungs showing where & how a circuit within a specific voltage circuit is triggered-completed etc. When you tested with relays ... did you hear some unwanted audio noise?
John J Spokas
Naperville, IL
APW & others,
Using relays for this seems very labor intensive to me.......so many wires to strip and connect....mini PLC's make these kinds of projects much easier IMHO.
APW
South
APW & others,
I did not hear any noise. I did use shielded cable from the relays to the speaker though.
APW
South
It is very labor intensive. Now that I have people wanting me to build custom speakers for their machines, I was trying to find a simpler way to do it. A PLC seems like it would be as long as I didn't have to use the PLC and relays. Can you recommend a PLC?
John J Spokas
Naperville, IL
I can't recommend a PLC without knowing what you intend to connect to it. Voltage and amperage for inputs and outputs and also a clear description of the operation the PLC will handle. My direct experience is with a particular brand BUT most PLC manufacturers have similar products especially at the mini PLC end of the spectrum...
John Spokas, APW & others,
Good point. I notice that by using a good quality PLC-HMI you can also eliminate even more wires on some projects.
Blanco
In a previous thread where you asked for advice on wiring the Floyd bell I suggested relays for you to use. The ones I suggested are not giant ice cube relays like the ones you used in your box. They are less than a 1/4" wide and you can use jumper bars to connect up to 10 relays together (commons and incoming voltage). Saves a lot of time on wiring plus you don't have to use such a bulky box to house them in. There is no reason to use a PLC for what your trying to do.
APW
South
Thanks, I'll look at those again.
APW
South
More context. I have 9 voices so looks like I would still need 9 of the relays that you mentioned.
John J Spokas
Naperville, IL
Good Morning APW,
1) What version/model of the Floyd Bell voice announcers are you using?
2) What is the source of inputs that you want to have activate the voice messages. Voltage and are they gonna be parelell connected to the existing car wash equipment or descrete/seperate connections?
3) At a quick glance it looks like if you have 9 messages from a Floyd Bell device which has 4 inputs then I think you will need more than 9 relays.
3) What area of the country are you located in? If you're close or near one of my travel paths I would stop by if it's okay with you.
Cheers!
