Nayax configuration
SprayDC1
Installing Nayax VPOS touch in car wash bays and looking for device price configuration and pulse directions. Anyone have directions?
I've found Nayax support to be good. My agreement with them includes unlimited tech support in the base price. They have sent me wiring diagrams for the config I wanted same day.
Nayax value should be factory pre-set to Quarters. [$.25] and Minimum charge amount.
Contact Nayax to confirm
With Dixmor LED6 timers:
Program “Coin Valu” [$.25]
Program “C” Time per coin/pulse to desired seconds per coin
Program “S” Number of coins/pulses to start to desired value
Program CC Pulse Value to [$.25]
Program “Dollars on Count Up” to display dollar amount charged as it accumulates
Connect Nayax Pulse 1 wire to Dixmor LED6 White/Black wire (Pin #8)
So…
If your start up price is $3.00 (12 quarters)
For 3 minutes (180 seconds)
180 seconds / 12 quarters =15
Dixmor “C” menu setting will be [15]
Dixmor “S” menu setting will be [12]
A credit card customer will see the timer scroll money spent as it accumulates…just like a gasoline dispenser.
So…
Does the #8 pin wire needs to be connected to any other wire other than the pulse 1 wire?Having a hard time with this! Thank you !
Does the #8pin wire needs to be connected to a different wire other than the pulse 1wire? I am having a hard time with this. Thank you in advance.
