W Waihekecarwash New member Joined Dec 6, 2020 Messages 16 Reaction score 1 Points 3 Jan 14, 2024 #1 Hi All, I have a Microcoin QL that has started to accept 10c and 50c coins suddenly. Is there an easy way to solve this. TIA
K Keno Well-known member Joined May 30, 2022 Messages 543 Reaction score 273 Points 63 Jan 15, 2024 #2 Make sure those any coins you are not accepting are turned off in the programming. May have bad electronics if it started accepting randomly and it wasn't accepting earlier. I would try to reprogram and go from there.
M Mel(NC) Member Joined Sep 5, 2007 Messages 208 Reaction score 9 Points 18 Location Eastern NC Jan 15, 2024 #3 Is the microcoin actually registering the dimes? I find that mine will let dims go through without registering if you push it with the right speed.
W Waihekecarwash New member Joined Dec 6, 2020 Messages 16 Reaction score 1 Points 3 Feb 2, 2024 #4 Found solution, easy, click button on side of unit 2x , drop coin through and it deletes it.
