Medeco Plug lock jammed
bigjws
Houston
I've got a Medeco plug lock that is stuck .. could one of you guys pm me the directions on how to drill it out? Appreciate it - IMG_2578.jpg
No problem I can send you that info. But before you try to do anything spray it down good with PB blaster or Kroil penetrating oil. The vault head looks like it's been under water for sometime. It looks like you might have to replace the housing the lock goes into, it looks pretty rusty.
bigjws
Houston
Thanks Randy, I look forward to the info. I've tried spraying it down a couple of times..and I just put another squirt in there this afternoon -- hopefully it'll work
Someone tried to drill one of mine recently. They used a tiny bit and attempted to go just into the pins and didn't leave any visible damage, but the key would go in really tight and it wouldn't unlock. I had to drill it. Before that they tried to drill another with a slightly bigger bit, but it opens just fine.
